BonScott46
- 3:19 AM
- Jul 20, 2016
- Sweden
Aren't those 1128 dawgs?View attachment 107523 660 dogs for a new 462
I have some that look like those that are stamped 1128, I think they were coming from the factory on the R models most recently. The 1122's are the same tooth pattern except without the oversized bottom spike. I like them both for different applications.Probably not. They may be getting them back to all be interchangeablemlike they used to be on the 044/64/66.
There's hardwood spikes for the 1122 that have the bottom pointing up. The R spikes all look like thoseI have some that look like those that are stamped 1128, I think they were coming from the factory on the R models most recently. The 1122's are the same tooth pattern except without the oversized bottom spike. I like them both for different applications.
Anyone know of a spike that will fit a Solo 651SP?
Do you need one? Let me check mine.
Get that abomination off that saw!!View attachment 107895
What about no spikes?
that's on the MOFO 026. It carries all limbing duties. I really just wanted a roller chain catcher on it.Get that abomination off that saw!!
Handy for noodling, too.View attachment 107895
I run MS362R dual spikes/roller catcher kits on my modded MS261's they are a good size for that power range. I'd just use them. I've tried 660 spike & 4 point ProSafety spikes and while they look great, the saw stands up when placed on ground, and they become really grabby putting a bunch of stress on your chain, sprockets etc. The 'R' spike kit is also the good solid metal like the old ones not the thin pressed nasty ones.="Dustin4185, post: 595139, member: 2032 What are thoughts on a ported 362? Bigger dogs or not? I like having the protection of them, but don't want something that is grabby.
I run MS362R dual spikes/roller catcher kits on my modded MS261's they are a good size for that power range. I'd just use them. I've tried 660 spike & 4 point ProSafety spikes and while they look great, the saw stands up when placed on ground, and they become really grabby putting a bunch of stress on your chain, sprockets etc. The 'R' spike kit is also the good solid metal like the old ones not the thin pressed nasty ones.[/QUOTE][QUOTE="Dustin4185, post: 595139, member: 2032 What are thoughts on a ported 362? Bigger dogs or not? I like having the protection of them, but don't want something that is grabby.
I swear I didn't take it... thanks anyway Dub!Do you need one? Let me check mine.
