Small right angle (RA) porting handpieces for Foredom motors.
srcarr52
6:46 PM
Iowa City
Anyone who has purchased one of these handpieces feel free to leave some feedback. Anyone have anything to say about the burr length, should I change them?
farminkarman
I like the red & black ones
5:46 PM
Neenah Wisconsin
I really like mine so far. I have only ported three saws since getting it. I haven't found a need thus far to have a different burr length.
Crocky28
11:46 PM
Scotland
I’m very impressed with mine. I’ve found the burr lengths spot on so far. I actually prefer it to my 90. I feel the contra angle is better to work with. Just a personal preference I suppose.
buckin-wood
6:46 PM
North East
So far so good here. I've touched up a cross 660 and working on a 7900 at the moment. Length seem good. A small ball burr might be handy. In full disclosure I'm new to playing with 2 stroke cylinders, I'm used to cavernous 4v 351c ports. I'm still ironing out technique and what works where.
I did bind the burr in a 7900 upper and the contra head gears survived. Not sure how many times I can get away with that.
Curious where you get that thick heat shrink you use on the handpiece.
srcarr52
6:46 PM
Iowa City
I'm glad you are having success. Yes, stuffing a burr usually tears up the head. Good news is that the heads are cheap. The heads I provide are some of the toughest I could find.
I've never been a fan of using ball burrs on a port wall as they are hard to create a flat surface with, I've found the egg shape help to maintain a flat surface. I do like to use balls for tunneling, like around a valve guide or pushing the skinny port edge wall towards the exhaust under the transfer bridge. In short a ball is good for running up and down the port in a small area or in a corner, the egg shape is better for going from side to side of the port and then moving up/down the port for your next pass.
The heat shrink is some generic 3:1 ratio, dual wall (adhesive lined), 3/4". I got it off ebay for around $1.20 a foot.
Ronie
6:46 PM
NC
srcarr52
6:46 PM
Iowa City
Ronie
6:46 PM
NC
This is why I had custom burrs made that are 3/16" diameter. 1/4" burrs tear up the heads fast.
When I first got mine I made up 1/4" burrs and as soon as it took a good bite it would strip the head.
srcarr52
6:46 PM
Iowa City
Depending on the head latch style some tear up the drive flat inside the cartridge pretty quickly with a 1/4" burr. The normal push button that has a sort of iris mechanism to hold the groove does not last long since the drive flat is short and strips easy.
I use and supply the YAD style head which have a longer drive flat and a guillotine style groove mechanism. There is also one style which has a flip over tang to locate the groove which is super sturdy but I have not been able to find a reliable supplier of those at a decent price. Both of these styles can deal with 1/4" burrs and they'll last a decent amount of time, the problem is it's easy to stuff a 1/4" burr in the back of the port and if you do you'll strip the gears of these styles. With the 3/16" burr is can suffer a few stuffings without stripping as it can generate enough torque to keep the burr from stopping instantly.
David Young
Safety First !!!!!!
6:46 PM
vt
Shaun do you have some ready to ship?
AKJonsereds
6:46 PM
Anchorage
Finally got to try mine out today. I personally think the shape of the burr is perfect for transfers and the size and angles work great. If a round burr is required, I did see some with the proper latch on eBay. I will be using the egg shape more often from now on.
I did have the head loosen initially and worried I had stripped it out extremely fast… but, a little twist fixed it up.
These are excellent tools and I look forward to using it a long time.
Thanks again Shaun! I definitely recommend everyone get one.
Kevinf1
OPE Member
6:46 PM
Ohio
Do you have any more available?
