Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
K Mueller
9:02 PM
Alaska, USA
That’s what I’m saying... you can’t post a picture of a Pro Sharp with a Solo Twin and 090 in the background. Kinda takes the grinder out of the spot light :rolleyes:
Deets066
AKA Deetsey
1:02 AM
i have only had one chain break before and it broke where it was joined i thing that the rivets were spun too much when it was put together. i have however had all of the cutters stripped off of a chain before they were on their last grind and only lasted about 15 minutes.
I’ve had a few fail in a few places. Watch some of the results of our chain races when we have them .......
You can even go back into some old threads and you’ll find all sorts of failures from files hitting the chassis at the rivets.View attachment 260123
This one had the driver open up at the front and whipped the operators leg pretty good. Chaps let him take only a bruise away.
As far as running your ported 390, gear it up a bit and start cutting some square wood ....... you’ll see quickly what you can get away with and what you can’t
pbillyi69
10:02 PM
USA
so after replacing the arbor on my grinder and it still having a slight wobble i actually measured it with a dial indicator and its only off by .001 I guess im just picky
Glock37
1:02 AM
Monroeville Pa
some Silvey files I fixed the copys and got these from the Siley site before they took them off the site
hope this helps
  • 510_Exploded_View - Copy.pdf
  • 510_Exploded_View.pdf
  • 510_Round_Chain_Grinder_Manual.pdf
  • Bar_Rail_Closer Exploded_View - Copy.pdf
  • Bar_Rail_Closer Exploded_View.pdf
Glock37
1:02 AM
Monroeville Pa
  • Bar_Rail_Closer_(BRC)_Instructions - Copy.pdf
  • Bar_Rail_Closer_(BRC)_Instructions.pdf
  • Bar_Rail_Grinder_Exploded_View - Copy.pdf
  • Bar_Rail_Grinder_Exploded_View.pdf
  • HDG-6_Exploded_View - Copy.pdf
Glock37
1:02 AM
Monroeville Pa
  • HDG-6_Exploded_View.pdf
  • HDG-6_Manual.pdf
  • Hi-Jacker_Exploded_View - Copy.pdf
  • Hi-Jacker_Exploded_View.pdf
  • Hi-Jacker_Instruction_Sheet.pdf
Glock37
1:02 AM
Monroeville Pa
  • Hi-Jacker_Manual.pdf
  • HJ_FW_Exploded_View - Copy.pdf
  • HJ_FW_Exploded_View.pdf
  • PDG_Exploded_View - Copy.pdf
  • PDG_Exploded_View.pdf
