Chiseltooth
OPE Member
Hello all, first post as a new member here and look forward to learning more.
I recently and gratefully acquired a really clean 1989 Husqvarna 242 ( no indication on rewind or top covers it’s an XP) ....
Well much to my disappointment she badly leaks down to the 1/2 mark in the oil tank. I couldn’t find much doing google searches as to this oil leaking issue. I wondering if the tank completely leaked out it would be more case halves but with this one leaking down to the halfway point if it maybe isn’t a loose pump or something forward of pump.
Were these little saws possibly prone to bar oil leaks?
While on the subject of the beloved 242, is this is a K095 mount (single stud) as I would appreciate knowing a good solid 15” or 16” narrow kerf bar and chain options. Wondered if the Cannon SuperMini were worth the cost vs a Sugihara or similar.
Thank you.
Thank you.
