147psi warm, I can't remember if I checked it stock, but I want to say it was around 120psi warm or somewhere low as seems consistent with Echo top handles.
I'd like to think I got roughly 36.875% faster cut time, but with a change in log size and an iffy first cut, and imperfect second cut, it's hard to tell. It's not as strong as I hoped, but it exceeded my minimum gains to call it a success, but then again I was going to take .050 off the base, but stopped around .0275 when I ran into alignment issues on the lathe, and at the same time found that though the plating goes to the top of the cylinder, it tapers to a wider ID, so I stopped working on compression.
I also had to grind on the engine cover and oil pump to get it all lined back up.
Video to come.
