New oem p+c. No rings or wrist pin 47mm bore dome top piston 55 dollars shipped
Has 2 small fin breaks on top head. 98 percent sure its a 66e jonsereds cylinder.
As with the 365/372, the larger bore 50mm 70e is the one people would be looking for and even then it would more likely be the later one with the bosses to mount the coil on the cylinder.
