SELLING 1128/1122 cylinders, 026/260 parts
2000ssm6
1:49 AM
NC
All these are used but clean inside unless noted, prices are shipped to lower 48. No offers or trades.
1. 044, no decomp, Stihl "B" cylinder. $145
2. 044/440, decomp, Stihl "B" cylinder. $145
3. 044, no decomp, slant fin, Not K&S, Mahle "A++++++" cylinder. $235. Not sure if this is from a 10mm or 12mm saw. *Might keep this one as I'm using a 044 again.
SOLD 4. 046/460, decomp, Stihl "A" cylinder. $155
5. 066/660, no decomp, Stihl "A" cylinder. Thin plating and a mark above exhaust port, would be a good practice cylinder for porting or if a company does plating. $30
Not pictured, a 046/460 with decomp, A cylinder. Thin plating, would be a good practice cylinder for porting or if a company does plating. $30
Cylinder #1, must be carbon streaks as none catch the tip of a pick.
Cylinder #2
026/260 parts;
oem Mahle 44mm p&c, piston is new but has some discoloring, needs rings, $125
Tree Sling'r ported oem Mahle 44mm p&c, piston is new but has some discoloring, needs rings. Squish band not cut, $175
3-MS 260 44.7mm pistons with rings, wrist pin and circlips, all oem Stihl. $50 each.
Brown8417
2:49 AM
Nova Scotia
Can you send me a pic of the inside of the 460 cylinder?
Brown8417
2:49 AM
Nova Scotia
is the 460 cylinder still available?
2000ssm6
1:49 AM
NC
2000ssm6
1:49 AM
NC
Bump, prices adjusted
Outback1
10:49 PM
California
5. 066/660, no decomp, Stihl "A" cylinder. Thin plating and a mark above exhaust port, would be a good practice cylinder for porting or if a company does plating. $40
Not pictured, a 046/460 with decomp, A cylinder. Thin plating, would be a good practice cylinder for porting or if a company does plating. $40
026/260 parts;
Complete PHO 290 for sale, smoked top end. It's been sitting under my bench for years, lots of grime, used some pb blaster on a few areas to show how it could clean up. Would be great for a 390 sleeper project. $150 plus shipping.
Still have the #2 cylinder? Could I get a picture of inside the jug please?
