KS Plainsman
- 10:54 AM
- Aug 7, 2019
- Kansas
My favorite burley is haunted bookshop. It’s certainly not dull. You should try that. It’s a good one.That was a pretty bland blend, especially for an aromatic. Starts out sorta OK. Definitely got the coffee flavors, but it was pretty weak, and went away pretty quick. Even after that, it was dull. Maybe that's normal for burley's, not sure. Didn't really taste the virginias. Definitely won't buy this one again.
Wow thanks for the review. I haven’t had that one and likely won’t make time for it.That was a pretty bland blend, especially for an aromatic. Starts out sorta OK. Definitely got the coffee flavors, but it was pretty weak, and went away pretty quick. Even after that, it was dull. Maybe that's normal for burley's, not sure. Didn't really taste the virginias. Definitely won't buy this one again.
X2. Good blend.My favorite burley is haunted bookshop. It’s certainly not dull. You should try that. It’s a good one.
I'll give Haunted Bookshop a go.Wow thanks for the review. I haven’t had that one and likely won’t make time for it.
X2. Good blend.
Bookshop stronger than both of thoseI've heard of that on a YouTube channel. Maybe it was Hobbiton Piper..... I'll have to give that one a try. Thanks for the recommendation, Jake.
I'm still a novice, but I was expecting a strong flavor like Old Toby, or Rivendell.
I kinda gambled with those 2. The others, I repeatedly hear how good they are. Cult Blood Red Moon has me pretty curious, with how much it's mentioned.I have not had old Dublin or Sherlock Holmes. The rest of those are sold.
If you like cherry and ghosted pipes Red Moon is cherry.I kinda gambled with those 2. The others, I repeatedly hear how good they are. Cult Blood Red Moon has me pretty curious, with how much it's mentioned.
I'm a novice at all this. So, we'll find out, if, or how much, I like cherry. . LolIf you like cherry and ghosted pipes Red Moon is cherry.
Uni flake I like.
Never tried Dublin or Sherlock and the others outside my flavor preferences.
Will do. Must be pretty potent stuff? Or, does cherry just ghost more than other flavors?Soooo run the cult in a cob only…. I’d try it still. In a cob
Some worse than others. Cobs don’t ghost nearly as much. And if by chance it did. Meh. It’s a cob. Use it for other aromaticsI'm a novice at all this. So, we'll find out, if, or how much, I like cherry. . Lol
Thanks for the advice, Jake. I appreciate it.Some worse than others. Cobs don’t ghost nearly as much. And if by chance it did. Meh. It’s a cob. Use it for other aromatics
Pretty much the same here.For what it’s worth I only smoke aromatics out of cobs. I specifically have a single cob I use. If I can’t find it I will use any of the others. But I won’t put anything like that in my nice pipes. Not that I have any of the super duper expensive pipes but like my savinelli only gets non aromatic stuff. Just in case it did ghost up bad
