Sty57
- 5:52 PM
- Jan 6, 2016
- Land of Cheese & Beer
Will Coil gap affect timing?
360how many degrees does a 560xp550 ignition. does anyone have the answer? thanks
Moderation,Is key to a long lifeI have found that several of my saws (definitely not all of them) run better with less muffler mods, and some of the 066/660s prefer a modified baffler (rather than a fully removed baffle).
Several members have stated that is because the porting (to the cylinder) was not done right, but I'm starting not to buy that. Other members have inferred that I'm full of Sh**, but I have documented this to my satisfaction several times.
Don't know why it took so long for the anvil to hit me in the head, but all of a sudden it seems real obvious that it is likely related to ignition timing. After all, when ever we used to open up the headers on our cars, substantial timing advance was required.
I guess if you are looking to make a work saw that does not "bite you" on start up, you may prefer a bit less timing advance and a more restrictive muffler.
I think I'm also going to advance one of my Asian 440 big bores more than .020 off the key and see what happens.
I think I've been conservative (on purpose) with the timing advance on most of my saws.
I welcome anyone else's thoughts/comments on this.
Does ignition advance make a saw run hotter? If so, why?
These mods could possibly work all together?
But your previous post had far too much modesty in it!
He did, but it was just his normal 98.6 degrees.
