Ronie
Since my 630 bit the dust, you can see it in the video thread, I'm going to take an old two piece coil 61 and put a 272 top end on it. All I've done so far is drill holes and install threaded inserts for an aftermarket 272 cover. After I tear the saw down and clean it up I'll put a little JBweld under the rear insert because the metal is thin there and half the insert it sticking through the other side.
