alleyyooper
- 8:54 PM
- Dec 26, 2018
- Michigan.
Went to plow the drive at Kare's moms house. I keep my 2016 Sno Tec snow blower there in Dads little garage.
I turned on the fuel switch plugged in the electric start and gave the primer 5 pumps set the choke switch to full choke
Key in and switch to on. I added stabil and sea foam to the fuel last spring.
Hit the starter button and it just cranked and cranked No start. It was 4 above out. Turned fuel off & choke because it looked as if it was flooded and comeing out the exhaust. Cranked it some more and no offer to fire.
Went to the back of the grarage and pulled out a little blower dad had bought before he passed away. I know it has sat back there for 4 years with out any fuel in it. It is a Troy Built 5hp 4 stroke 21 inch paddle machine. I have one like it but mine is a 4.5 HP 2 stroke. Dumped a gallon of fuel in it primed it and set the choke and it fired right off then died. I had set the choke the wrong way off instead of on. Set the choke properly and primed it again fired right up and ran. I allowed it to warm up then went and cleaned the 3 inches of snow from the drive way.
When I finished I tried the sno tec again and still no start. Going to buy a new plug or two and change it out and with out primeing or chokeing and see if I can get it to fire up, hopefully tomorrow.
Al
Al
