srb08
Doesn't play well with others
- 11:50 AM
- Sep 30, 2016
- Mid Mo
Lance, have you thought about slugging the barrel?Do you know what they are sized to?
To streamline the process of trying to find the right diameter bullet for Ruger single actions, I used egg shaped sinkers to slug the barrel and pin gauges to measure the cylinder. Made the process a lot faster. I use a brass hammer to start the sinker into the barrel, then use a cleaning rod with a brass jag to tap it through.
Below is a 1/4 oz weight, with an OD of .378. I use this size for .38/357 barrels.
Should work fine for a 9mm. You will need a good micrometer to measure the groove diameter.
Being a takedown rifle, you have the advantage of being able to start the slug from the breech.
Here's one that I used for measuring a .45C Bisley.
For a cheap and easy way to measure a barrel, it works pretty well.
Just a thought.
