FergusonTO35
- 8:37 AM
- Jul 9, 2017
- Boonesborough, KY
Yes, it was. Thanks!
Damn!My parallel dimension self must be hitting the Powerball 'cause I'm 0 for 2 on new guns right now. I managed to try out the carbine this afternoon at 25 yards resting on shooting sticks. Ammo was the previously mentioned load that all my handguns like. At least half of the shots fired were major flyers. For example, I fired 10 shots at the bull in this photo. Four were reasonably on target. One was about 4 inches high, two were high and right and two were low to the right.
Upon cleaning, I didn't see anything amiss. There was about the usual amount of powder and bullet lube fouling, no lead deposits I could see. So, maybe the barrel is a bit overbore? Ive never found a 9mm that would not shoot these bullets at least reasonably well, including Glock factory barrels. I suppose I'll try some endangered species factory ammo next, then maybe some .358 bullets.
The good news is, function was 100% and the carbine is lots of fun to shoot. The factory sights are great, same sight picture I have on most of my other long guns.
With the grip change, did the cast bullets shoot better or is it going to be a jacketed only kind of gun?Tried the carbine again with 4.5 grains IMR Target and 115 grain FMJ. Discovered that, as I suspected, my grip on the wrist of the stock makes all the difference. A poor grip and flyers all over the place. Wrapping my fingers firmly around the wrist and then stretch my trigger finger way out there to squeeze the trigger with the first knuckle and it shoots almost dead on with this load. This way of gripping feels strange given I'm used to lever actions with the trigger further back against the wrist, but it works.
I believe the forend is free floated on those rifles.Just curious, but those appear to betakedown rifles so the barrel is not free floated. Does it make a difference how or where you hold and put pressure on the forend/barrel? I've seen it make a difference on other rifles.
I shot 147grn cast bullet's I'd made in my friends kel tec extremely accurateOk, some progress and challenges. Tried the carbine with 3.8 grains IMR Target/Lee 356-120-TC today, a load that my pistols do great with. Absolutely horrible, many of the rounds didn't even strike the target paper! The lower left is supposed to be a 4 shot group. The group that was supposed to be in the center was wandering low and to the right.
Trudged back to the house and rolled up the same load with the Lee 358-125-RF, which works great in every 9mm/.38/.357 Ive ever tried it in. A dozen were sized .357, a dozen sized .360 which is what I use in the Marlin .357. Instant improvement, the group in the lower right is two groups of five with different elevation settings. The .360's seemed to go wider, as the group in the top left shows. In the top right, the rifle seemed to be trying to go back to wandering zero, however I also noticed the forend had worked its way loose by this time. It is secured by only a single screw, guess I need to loctite it. More research is needed!
