GlocknStihl
Derelict OPE Member
- 9:23 PM
- Aug 12, 2018
- At God's feet
The only things we don't like around here are limiter caps and jms.I'm sure most of you won't like it because its aftermarket, but I just thought I'd share it.
How is the compression ?
Where did you buy it ?
Numbers # ?
You got my interest .
Numbers # ?
Subbed...
If you would be interested to have one turned into a race build put me on the list !$
Got any timing numbers?Done! I've been testing for durability, and I cant think of a better test for this purpose.
CoolI dont currently have a saw to test it. So I'm passing them to guys who can answer that for you.
I received one also and thought it looked ported already in the intake and exhaust.
I see the same. That’s what’s annoying about AM, they always fail at some part.Could be partly the photo angles but the exhaust port on this one looks quite noticeably different than the op's, flatter on the roof and more radius on the floor.
Again could be the photo angles but the upper transfers don't appear to be very 'directionally orientated' toward the intake wall, particularly on the primary side.
And looks like the 'cross sectional thickness' of the bridges are even front to back, rather than tapered to match the trans tunnels as on the oem and mmws cross. I'd guess that's likely a byproduct of the 2mm overbore.
Can't tell from any of the pics if the trans tunnels are angled in toward the exhaust like oem or straight and following the bridges.
Will be interesting to see some timing numbers...
