Anthony_Va.
- 11:01 PM
- Oct 18, 2016
- Virginia
I've had this saw for a few years. It was given to me dead with a scored hug from straight gas or dirt ingestion. I also found that the oil pump seal was bad. I decided to go through it completely.
I changed everything, crank bearings, seals, rebuild carb, new lines, tank lids, air filter, etc. Changed the oil pump out to the newer style.
Finally I found a good used jug on eBay a week or so ago that turned out being excellent. Bought a new golf piston and caber rings. Put it all together last night.
Today I bought a new plug and filled the gas tank. Pulled it about 6 or 7 times and got a pop. flipped it to run and pulled it twice and she came to life. Only thing is that it seems to be flooding itself out. It run and rev up for a few seconds then it'll die. The other thing I noticed is that the vent in the gas tank lid is letting fuel leak.
Other than that I'm happy it even started at all hahaha. Pics to come when I get home. I had a 42 inch stihl va bar that was supposed to fit it but the groove in the bar isn't wide enough to go over the studs. I'll post pics of that too maybe you guys will know what it will fit.
