popopboat
- 7:23 AM
- Sep 17, 2019
- Croatia
Hi,
basically my ms650 that i repaired acts real fishy.
Starts flawlessly, idles nicely, runs steadily and without any fluctuations in rpm and/or sound, BUT
tends to die after WOT, or simply pressing and releasing the throttle quickly.
RPMs go down to almost dying and/or sometimes slowly dies, but if i hold the throttle and release it slowly that does not happen.
It does not increase rpm by itself and does not spin the chain, carburetor settings are : bit less than 1 turn H, 1 1/2 turn L, nothing unusual to compensate for air leak, therefore id remove air leak suspicion.
I had those symptoms with bad nozzle check valve, this one works BUT i found out that there is an aditional hole parallel witht the main nozzle, doesnt that kill the purpose of the check valve?!
Also checked carb on my 064, has the same additional hole.
The one on the picture bellow.
Membranes are fine, diaphragm looks good, does not bind or anything.
Im running out of ideas, anyone has still some left?
