- 9:50 AM
- Dec 30, 2015
- Brewster, NY
Sounds good!
Not only does the 462 have a short stroke (34mm) but it also has a 'lighter' metal flywheel. Is it lighter than a 460/461 poly FW? What affect does a lighter flywheel have besides benefiting acceleration? Does it affect torque? powerband? Does the M-tronic help offset negative affects of a lighter FW if there are any?
I think it would be interesting to see a stock 462c-m up against a standard ms462 tuned to a brown plug and see what the difference if any is. Pretty please. @tree monkey @Redbull661
Thoroughly enjoyed your video there AlexA few cuts, some mad revving and an M-TRONIC reset post timing advance and muffler mod.
Just watched your video alex named "mtm 625sx the end! hello ms 462.) Absolutely terrific editing. The vid was inspiring.A few cuts, some mad revving and an M-TRONIC reset post timing advance and muffler mod.
It would have more inertia, and slower throttle response, but it would not pull any harder.
That would work if you kept the trigger pulled all the time, not a good idea.
If you pull the trigger to cut the branch, fast throttle response is what you want.
Two seconds into a cut, it won't make any difference at all.
