ms 461 woods port race thing
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:40 PM
Provencal, Louisiana
You can even IMPROVE on the flat roof by having a curved roof. All you have to do is trim the top of the piston to match the curved roof. A straight line is the shortest distance between two points - if you take a curved line between the two points, you INCREASE the distance between the two points. - In other words, you increase the size/length of the opening when it first opens.
That will give you an even stronger pulse to work with in an expansion chamber. However, we are trying to eliminate the short-circuiting on this jug, which is entirely a different problem.
We aren't working with an expansion chamber and tuning the exhaust, we are working with FLOW. We need to correct the flow so that the intake mixture stays in the jug to be burned.
It will either have to be restricted at one point or increased in another to balance the primary. Maybe epoxy in the quad entrance or the port opening or by adjusting back pressure , (Stuffing). Thats a big baffle in the muffler from the factory on the 461. Removing that baffle may alter the flow through the transfers from the way they were designed to flow from the factory
Keith Gandy
12:40 PM
tree monkey
12:40 PM
wi
gonna do this one of these days
1:40 PM
I'm missing what that will do. Why will a notch passive over the bridge (not an open port) change anything?
Redbull661
661 hoarder (BlueBallz)
12:40 PM
wisconsin
Well i made it to Scottys. I counted 16 cars in ditch on the way!
Thankfully I had the force on my side...
(light saber next to the red bull display. Had to get it lol)
