G
Greenerpastures
Guest
Hi Wilhelm, thats a long enough list of needs.So far identified issues:
- clutch assy needs replacing, as in weights and drum, clutch drum needle bearing shot
- oil pump not oiling, oil leakage coming from under the clutch, oil volume screw head broken off
- lots of chain slap rash
- muffler boogered and poorly fixed
- third top muffler bolt broken in cylinder thread
- cylinder cover and chain brake flag have heat damage, molten plastic
- cylinder AV mount broken
- the outside of the saw was thoughroughly cleaned for the pictures, underneath any and all covers everything is infested with molten rubber that vulcanized itself to the saws surfaces
Tested and deemed good:
- engine starts, idles and blips good
- piston and piston ring look good
- nothing appears to be bent like it was the case with my PS-7310
She requires attention, I'll replace everything I need to restore her.
The oil pump would be my first fix.
Regarding the top muffler bolt broken in, if you get someone good with
a welder, even a mig, but tig would be easier to handle, to weld / build up
the broken bolt, to a length where you could either catch it with vice grips
or weld a nut on it, either way to turn it out, very slowly, uses wd-40 to cool
and lubricate it, back and forth ever so slightly untill it moves, even then keep
turning it slowly out, a small rotation at a time.
OR, use a spring to pull the top off the muffler into position,
you will need to find something to catch it on the cylinder through,
but as a last resort I mention it, it should come out with the welding,
just cool it after every few dabs of weld, dry, clean, and weld again.
You mention heat damage, is this from the muffler do you think.
Pictures can be so deceiving, I do not know how many tractors I've
gone to see that looked ok in pictures, there should be a punishment
for this, it is in essence false advertising.
I will be thinking of you Wilhalm, Regards, john
