cmhmhh
Active OPE Member
I have a Honda Push Mower, Model HRR2165VKA, Serial MZCG - 7940269 on the bench for various reasons. I am attempting to remove the blade adapter from the crankshaft. Honda 06726VG3305 Blade Adapter Assembly. I have deformed the end of the jam bolt on my two jaw puller that I normally use trying to get this thing off. It has been soaked in PBlaster and left under puller tension for days with occasional pounding to try to break free with no luck.
I do not have access to oxy/acetylene torch setup, so heating is out for now. What sage knowledge and advice is out there on how to get this off.
Many thanks in advance from North Central Ohio!
CMHMHH
CMHMHH
