Lever action rifles
Funky sawman
Pony Power
1:44 AM
North idaho
I gave up on lever action rifles after owning a winchester in 44 mag, then a 94 marlin in 44 also. Both new guns, they would jam about 99 percent of my own casted keith style flat noses, and about 75 percent of the factory jacketed loads would not feed either. Got me a Ruger 77/44 bolt gun and it feeds everything
srb08
Doesn't play well with others
3:44 AM
Mid Mo
@srb08, I am confused, So I can now run my 22 mags in my .357 mag. revolver. Maybe I missed something.
No. The only thing you can shoot in a .357M revolver is a .357M, .38 spec, or similar type cartridge.
The .22M is a different diameter and wouldn't work. It's also a rimfire.
You shouldn't shoot .22lr in a .22M.
FergusonTO35
4:44 AM
Boonesborough, KY
How were they jamming? Would the round get stuck before it entered the chamber, or would it not go into the chamber all the way? If the latter, then sounds like a finish reamer would have taken care of it. My Browning BLR will only chamber factory ammo easily, everything else is pretty snug. The 'smith is going to do a chamber casting and open it up some. Sometimes, minor variations in bullet molds make all the difference. The Lee C309-150-RF always got stuck in the leade of my Winchester and Marlin .30-30's. Yet, the C309-170-RF works perfectly even though it has a longer ogive!
Funky sawman
Pony Power
1:44 AM
North idaho
They would get jammed trying to feed, lever would stop about half way. Tip of the flatnose bullets would hit either the top of receiver or the barrel were the chamber starts. Hornady flex tips fed perfectly
Funky sawman
Pony Power
1:44 AM
North idaho
I had the marlin first, then was told by my local gunsmith to run from this rifle, run fast and hard! Ok so I did. Then got the winchester as what was recommended by many others, but same issue lol. I then said the heck with lever guns and back to what I know which is a bolt gun
Funky sawman
Pony Power
1:44 AM
North idaho
Gotta stay with what works for ya. I've always had good luck with lever actions, but I like bolt guns too. Strangely, I think I've had more feed jams with the bolt guns.
I've had my fair share of issues with bolt guns, especially the custom ones. Had a 460 short A-Square built on a pre 64 model 70 winchester action, that was a nightmare. Had a custom magazine box made and it would feed the first one in the hole but not the next. After 10 hrs of paying an expensive gunsmith to rework the feed ramps and lips it finally worked, at that point I was so stressed out about that rifle that I just sold it lol
FergusonTO35
4:44 AM
Boonesborough, KY
My .257 Roberts is on a .30'06 length action, which is really too long for this cartridge unless you are using really long VLD slugs. What this means is, the fifth and last round in the mag gets pushed forward with each round fired until it nose dives when it's turn comes to feed. No big deal to me, if I haven't made something dead with 4 rounds then a fifth is not likely to change anything.
FergusonTO35
4:44 AM
Boonesborough, KY
With my cast loads I tried all kinds of different C.O.A.L with no success. I did find that when it jammed it tried shavings lead off the side of the bullet.
Do you recall if the rifles would feed factory flat nose ammo properly?
Funky sawman
Pony Power
1:44 AM
North idaho
The only flat nose factory ammo I had was swift brand 300 grain swift a frames, jacketed of course. They did not feed. If I recall correctly, the winchester would kinda feed 44 special cowboy loads with a round nose lead bullet around 200 grain
Funky sawman
Pony Power
1:44 AM
North idaho
The marlin was horribly inaccurate also, the heaver the bullet, the more shotgun buckshot pattern I got! The Win was super accurate, well at least minute of deer lol
FergusonTO35
4:44 AM
Boonesborough, KY
What caliber was the Marlin? The .44's used a ridiculously slow twist, like 1:39, which seldom worked with anything past 240 grains.
