- 4:34 AM
- Jan 24, 2018
- Extreme Southeast CA
I’m a desert rat and would certainly want heat on my fingertips in a cold climate…do they have a kit to put A/C on them?
A 70E? maybe was a hotrod that could be made to runOh…@spike60 I have a burning question I’ve been meaning to ask. Is there an all metal vintage Jred 70-80cc saw that is closed port and will run with modern saws ported?
I have a 70e ported by awol. Has an 044 piston in it. She flysOh…@spike60 I have a burning question I’ve been meaning to ask. Is there an all metal vintage Jred 70-80cc saw that is closed port and will run with modern saws ported?
Can I borrow it? :-D Or make a vid!I have a 70e ported by awol. Has an 044 piston in it. She flys
Never heard about that one. Is that just a straight drop in?I have a 70e ported by awol. Has an 044 piston in it. She flys
No. I believe he had to modify the piston and make it a pop up. I know he cut squish and maybe the base etc.. I was planning on putting in new crank seals so i will take off cylinder and take some pics..it definately can outperform some ported and machined 372 oe's.Never heard about that one. Is that just a straight drop in?
Thanks!Yes Dave. They can be used and will not interfere with each other. But they will both be sitting higher and there will be less room between the cover and the handle. Will be a little tight for someone with big mitts, or anyone wearing gloves.
Also, since I’m here I just got a 2175 from @Cat 525 that @huskihl ported. Only ran it a bit in small wood and she’s not quite a beauty queen but with the chain resting on the wood at idle, when I stabbed the throttle it tried to slam myself and the log together and chips exploded everywhere. I think she’s gonna be my new favorite.
