M2theB
- 11:34 PM
- Apr 2, 2018
- Central Mass
I’m working this saw for friends uncle.
Came to me with low compression and I found the top toasted.
Also found that the intake clamp felt loose on disassembly. It was my immediate suspect for an air leak.
Replaced the top with a 372 xtorq kit, meteor.
Started fine and cut well. But surged on idle. So started looking for another air leak. It’s has a very slow one. Very slow and my set up on the intake is a source
PTO seal seems fine under pressure.
I did discover that the oil pump screw talk directly to the chamber. Pull those out and it direct hole to the crank. That doesn’t seems right. Anyone know??
And I’m starting to think the clamp on the boot is too big. The two barrel nuts bottom out before I get to what I think should like the right torque.
anyone come across this on these saws?
I’ve ordered a new carb kit too
