redram06
OPE Member
- 2:41 AM
- Oct 9, 2021
- north carolina
hi all, i'm working on a neighbors JD that's been setting (outside) for about 2 years. it's a john deere lx255.
my current issue is that i can't get the pto to come on. i checked the 2 fuses on the circuit board and they're good. i also unplugged the wiring harness from the clutch and jumpered it with a battery and the clutch engages. i've also checked the pull switch that activates the clutch and it checked good with a meter attached to the 2 terminals on one end. could the printed circuit board be the culprit that keeps it from coming on? i have jumpered out the seat switch and tried to engage with the brake off and in park position. any ideas on where i can check next? thanks in advance for any help.
