Clarkbug
Active OPE Member
- 11:20 AM
- Sep 19, 2022
- Northeast
Last year I picked up a Husqvarna Z4824 (Model 968999512) from a coworker to replace an old Toro I had that was starting to really act up. His father had passed away so it was a mower be couldn't use, and only had some idea of the history of it.
It has always been a bit "jumpy" and not the smoothest to operate. I have fixed several issues, like no spacers in the front wheels and one of the caster forks not having a grease zerk to try and assist with the steering. I replaced the ball joints on the end of the control arms, and would add new dampers too, but they are listed as NLA.
I have tried to also adjust the linkage, but on this machine there really is hardly anything that seems to be available at the hydro itself. It seems that the left hydro is getting weaker, as evidenced by trying to drive straight. The left lever can be full forward, but I have to move the right one less to track straight.
Is there anything I can check or adjust on the hydro at this point, or is it a case of run it until it's not usable? I know it's a residential grade mower, but would like to limp it along for a while longer if I can. Makes me almost regret getting rid of the Toro now....
