Husqvarna 350 intake adapter removal
bigfrank
9:12 PM
NorCal
If you dont change that boot and clamp at some point it will eat itself and you wished you had changed it.
I did change it. Didn't make any difference in the problem I am having, but the boot is much tighter.
Husky268
12:12 AM
Georgia
Been a while since working on these but like huskihl said those bolts get loose and getting them back tight really wont work u need to tear down and reseal.Also check cyl to base where impulse is created sometimes u need to grind a little but really look over closely and i guess you put new impulse line on.just about has to be in bottom end.
9050lx
12:12 AM
FL
The little plastic nipple on the intake boot that goes into the cylinder can get hot and melt closed.
JohnnyBlade
JUST GONNA SEND IT
11:12 PM
Momence,IL
Im guessing its in the carb. Carb kit and a cleaning. Sounds like everything else checks out :D
9050lx
12:12 AM
FL
Check the order of gaskets in the carb.Common issue.How bad are the rings?Do they have any tension?
