Husqvarna 272/Jonsered 670 Repair Thread
4:54 AM
I have a question. What does it take to swap out the two piece coil to the one piece?
Onan18
OPE Sponsor
5:54 AM
Georgia
Flywheel key back in place.
Lay the flywheel back on, I like to put a socket over the crank and give it a sharp tap to make sure it is seated on the taper.
Tighten the nut well.
Onan18
OPE Sponsor
5:54 AM
Georgia
On to the carb box. There are a couple of grommets that are more often than not missing, it is a good idea to replace them.
Remember the intake difference that was mentioned earlier, here it is. The 266 block has separate bolts holding it onto the cylinder, 272 uses the carb screws.
So the 272 screws are different.
