Dirtmagnet
- 11:25 PM
- Jan 10, 2017
- Detroit
Hello everyone! I have been a firewood cutter for 20+ years and a chainsaw "enthusiast" for roughly 4 years. Before I get to my questions about the 545, I thought I would provide a very brief background of myself. My father heats his home using an outdoor wood burner and uses roughly 8-10+ chords per year depending on the weather. He lives on a nice chunk of property with primarily hardwoods (White and Red Oak along with soft Maple, Pine and a small amount of Poplar). My father is getting up there in years, so I have done most of the cutting for him although he also really enjoys woodcutting to this day.
My history: I have rebuilt an 026, 024 Super, Husky 359, turned a Husky 261 into a 262xp and JUST started playing with porting using a Husky 350. I am by NO MEANS a pro at this stuff yet, but have been mechanical all my life. I really enjoy it.
I have been lurking on various saw forums for years, but never signed up. I considered becoming a member of Another Site but I am not interested in the childishness of that particular site. This site, on the other hand, seems to be very informative AND friendly with tons of goofing around that I very much enjoy. So, I say thank you to everyone on this site for their information and willingness to share!
On to the saw: I purchased our first autotune saw (2012 545) on eBay after running a friends. I thought it would be the perfect saw for my dad considering it is extremely smooth, light and tunes itself for the weather. When I got the saw, it ran ok and had good compression, but I pulled the muffler anyway to check the piston. There was minor "scuffing" on the intake and exhaust side, which was not ideal, but the major issue was that the ring was stuck. Bummer. I decided it was a good idea to at least pull the cylinder and take a peak. Luckily the cylinder is in good shape with no gouging and I was able to unstick the ring by carefully working it and sparily using degreaser. It appears that the saw was running really heavy oil mix. The internals were extremely oily and i think this caused the ring stick. Also, the carbon deposits on the top of the piston almost wiped off by hand.
So: I will clean up the piston and check the ring gap in the cylinder when everything is cleaned up, but my questions are:
1. If I rebuild the carb with a new carb kit, how do I reset the Autotune system?
2. Is there anything I should be aware of with these autotune saws in terms of failures to look for or difference operation compared to a "carb" saw?
3. With the base gasket removed, I should get right at .020" squish. Is there any clearance issues with this saw that I should be aware of if I drop the cylinder 0.020"?
Thanks and sorry for the stupid long post..
