Is this after you bent the reeds out? I’ll check what mine is turning at wot after the mods in the morning.@SOS Ridgerider @Simondo I started her up tonite and only could get her to 11k. I thought 15.2 was a little bit high, as she did not sound like she was screaming. I've got to check my meter, its been acting up lately. Anyway, I throttled her up and let her idle back down, but she came to 4k, instead of the 3k. Put on the chainbrake and leave it on for a couple of seconds, and when you release it its back down at 3k. Dont like that. I looked at the sprocket and it didnt even have a mark on it like it had been run much. Going to look at the muffler and piston tomorrow. What do you guys think about the idle problem?
I just checked mine for idle and max rpm. When it’s good and warm it idles around 2800-3000. Max rpm is right around 13,500.@SOS Ridgerider @Simondo I started her up tonite and only could get her to 11k. I thought 15.2 was a little bit high, as she did not sound like she was screaming. I've got to check my meter, its been acting up lately. Anyway, I throttled her up and let her idle back down, but she came to 4k, instead of the 3k. Put on the chainbrake and leave it on for a couple of seconds, and when you release it its back down at 3k. Dont like that. I looked at the sprocket and it didnt even have a mark on it like it had been run much. Going to look at the muffler and piston tomorrow. What do you guys think about the idle problem?
Carb kit sounds like a good start and check the fuel lines, they had issues with them cracking at the tank. The Carb on mine works well enough, but I would likely try lowering the pop off pressure a little and see if that helps.I've heard of several people that have had this problem. Havent heard of a remedy though. I can now only get it up to a little over 9k, maybe it needs a carb kit.
