Duce
- 5:15 PM
- Feb 6, 2016
- Roscommon, MI
I purchased a nice vise similar to that, same brand, got tired of breaking cheap ones.
You are correct...Thats where I think I saw it at.
I do it on the bar, no race chain, just work chain, but I can do it just as fast as round.
I think you'd get an even better corner if you used a chain vise Mike. No movement. Much more precise.
Your just saying that cause they will spank your dollys!You shut up...
...and huskys stink
The inside top plate = the angle down (this just removes the chips unless you are milling)
The Inside Side Plate = the angle back (this is the most important angle as it cuts the wood fibers during a cross cut)
Putting a 45* tilt on the file will produce the other angles.
If the outside side plate is not less than 90*, the chain will not self feed well.
If you "rock" a corner (even with just a tiny pebble), your chain will not cut right until you file it out.
Full Chisel Round (like Stihl RS) is easy to convert to square. (On the East Coast, square file chain is hard to find).
The angle that you see looking down at the top of the chain pretty much is what it is because the other angles are more important. The top angle will also change with different brands of files, as the bevel sides are different angles for some manufacturers. You need to get the file pointed down enough (more blunt) so that the cutter stays sharp longer, and adjust your file roll so that you have 0-3° of forward lean. This usually leaves about a 15° top plateGents after giving it a long hard thought, I have to self report, the double bevel files have arrived. I have a new mountain to climb. In the beginning it is definitely harder than I thought, all I need is patience and the will to get through my mistakes.
Gents everyone has their system, but the vice from @Homelite410 is a godsend for me, tooth locks in perfectly without any movement.
Mike I wanted to ask about the top plate or per Madesen's drawing the Top Outside Plate.
Are there good angles for work cutting, ripping, and how much it too much where no gains will be achieved.
I will be hand filing, I will most likely have some variations from tooth to tooth. Would those variations from tooth to tooth if too large or inconsistent cause any chattering or reduced cutting experience?
