- 2:29 PM
- May 27, 2018
- Omaha, NE.
Those ign. switches can be cleaned by spraying carb cleaner through the key slot, to flush out the crud. Dry with compressed air, and spray with a multi-lith spray to relube. Mine has been working fine for 4 or 5 year since the last cleaning.
New switch in and starts right up, although I now question if it was as simple as I needed to hold the brake pedal harder for the safety switch. Let it run, all but, out of gas and must have got a little crud in the carb so surging a little now so may run some seafoam through it. Took 3 loads of wood to the back and much easier than using the wheelbarrow.
Thanks again for the advice on the switch.
