jeepsnchainsaws
- 10:28 PM
- Aug 6, 2016
- Central Missouri
PineHere's a sound clip.
Homelite Super XL- Muffler mod and test run.
They could have been put in 3 places that I know of, depending on vintage. On the top, late 70s, on the side where the handle is, early mid 70s, early blue ones had it on the bottom of saw.Anyone know where to find SN and UT for a 150 homie?
Also sometimes the tag falls off. If you think the carb is original, the saw can be dated from the carb.Anyone know where to find SN and UT for a 150 homie?
Most of the time either the duckbill is missing, or the lines are crossed if the saw was ever worked on. Since pics are worth 1000 words I've included some.Anyone recall a rebuild thread for the xl2 oiler? Just rebuilt a dumpster find and no evidence that the oiler works. Might just be that its stingy with the oil. Havent done more than a few minutes cutting
View attachment 41833 View attachment 41834
Line to square fitting is to pump, goes to bottom of oil tank, (see pic)
the other is impulse line, goes to top of tank. In the oil tank, must have splintered bronze connector and duckbill (see pic)
Homeowner grade saw with manual and automatic oiling. 42.5cc. AV. .325 or 3/8 lopro chain. 18 inch bar max.Homelite 245 what's your thoughts
You can probably find most of it here. http://www.leonschainsawpartsandrepair.com/store/c11/Homelite_150_Chainsaw.htmlNeeding a fuel cap, a muffler, and a throttle rod for my 150 im rebuilding. The rod decided to disappear to parts unknown. Probably eloped with the hdc carb circuit plate screw (which i replaced from a parts carb). Anyone got any theyd part with?
Is this the one you need?it runs if you squirt gas in it, but that's all I know. Oh and it's complete.Needing a fuel cap, a muffler, and a throttle rod for my 150 im rebuilding. The rod decided to disappear to parts unknown. Probably eloped with the hdc carb circuit plate screw (which i replaced from a parts carb). Anyone got any theyd part with?
Here's the rod http://www.leonschainsawpartsandrepair.com/apps/search?q=69136A guy I do business with had a Homelite XL2 sitting in the floor. He is trying to retire it for his dad. It is missing the top handle half and the rod. He found the spring AM, but can't find the rest. Dies anyone have any of the missing parts?
Here's the rod http://www.leonschainsawpartsandrepair.com/apps/search?q=69136[/QUOTE
Thanks I will forward to him.
I have both pieces for the cost of the shipping. PM if you want.A guy I do business with had a Homelite XL2 sitting in the floor. He is trying to retire it for his dad. It is missing the top handle half and the rod. He found the spring AM, but can't find the rest. Dies anyone have any of the missing parts?
I will let him know today or Monday. It is a nice little saw. Does the top half of the handle snap on or bolt on? This one snaps down somehow.I have both pieces for the cost of the shipping. PM if you want.
