TJ the Chainsaw Mechanic
Old Homelites rule!
- 12:37 AM
- Jan 7, 2016
- Next to my bench at the shop, Oregon
Time for another repaint folks. This is my 4-20 Homelite. 4 horse 20 pounds. Saw had been sitting for over 20 years and with some fuel system work fired and ran like a champ. Even cut some wood with it after getting the roller nose bar and chain broke loose.
Plans are....repaint as being done already....new decals.....and tune up. Gas tank needs to be blasted inside as the gunk is pretty bad and even a flat head screw driver would not chip the crap off. Don't want to eat anything away with acids so I'll bead blast it.
Got a good jump start on painting today. After the saw is painted and back together I'll wire wheel the bar...heat it and oil it.
Should be a fairly quick project long as things are smooth sailing. Need a few gaskets which I will probably make.
