tree monkey
- 10:54 AM
- Dec 14, 2015
- wi
I heard machine work was overrated and all ya need is a dremel and some wood burrs.
I make em small to start with. You can always open em up if you have too much comp.How do you go about figuring out the combustion chamber size and shape?
Have you been peeking in the shop window, again?I heard machine work was overrated and all ya need is a dremel and some wood burrs.
When I would do Banshees, Blasters, etc, I used a graduated cylinder for that. It worked well. I often found inconsistencies within oem and am heads.You can also check by volume, measured by CC
The split transfer is genius. It look like a steel divider? If so, why not aluminum?
