Handlebar replacement on a 020T?
LittleLebowski
10:11 AM
VA
How hard is this for a crayon eating Marine?
cus_deluxe
terms of service violator
10:11 AM
Michigan
Theres a screw that comes in the end of the handle that screws into the buffer. The buffer screws into the case. Its gravy
PA Dan
10:11 AM
White Oak PA
Take the cover off the right side of the top handle. Pop the switch out to expose the screw for the handle. Take screw out and pull old handle off. Stick new one in and get screw started and it will pull the handle all.the way in. On the lower av I use a 20mm open end wrench and tighten it to the case then reinstall the lower handle screw.
Chainsaw Addict
GO HOOSIERS
10:11 AM
Indianapolis
I had problems with buffer and new screw. Handle itself was ok. Had to swallow my pride and have dealer friend help.
Otherwise, a really handy saw.
I lucked out and found perfect small case cheap.
Sent from my SM-G965U using Tapatalk
Chainsaw Addict
GO HOOSIERS
10:11 AM
Indianapolis
It's a Stihl case. Maybe it was for an 011 or some small saw. Another nice find was case that fit MS 170.
