Grinding help
Jscb1b
Mister Slapnut
3:58 PM
AZ, USA
When grinding chain, do you grind from the inside out like filing or outside in to not leave a bur?
Philbert
Chainsaw Enthusiast
5:58 PM
East Dakota
Both!
Most current grinders do not have reversible motors, so one dude is ground inside-out, and the other outside-in.
Not a big deal. Any burr dissapers in a fraction of a second in the wood.
Philbert
blades
5:58 PM
Leroy, WI
yep one way wheel - its an OSHA thing so as mitigate breathing in grinding dust. converting back to dual directions can be done with a little creative wiring. there are how to diagrams around maybe utube vids as well. going back more than 30 years the units were bi-directional.
11:58 PM
I am always grinding from the outside in on my AMA MAXX (Italy) grinder.
It has a chain clamp that swings around for LH/RH teeth.
blades
5:58 PM
Leroy, WI
hey Wilhem how old is that grinder of yours? , The ones I was finding under AMA are not any different than everything else out there. How about a pic of it. Always looking for a better mouse trap that doesn't break the bank.
11:58 PM
I think it is a 2009., will check and take pictures tomorrow after work.
11PM for me now and working the AM/morning shift.
11:58 PM
I remembered correctly, 2009. unit.
The looks of it.
Available angle adjustments.
Unfortunately the grinder will not go under 55° although I feel the desire to go shallower when grinding - but 55° is fine, just not aggressive.
11:58 PM
LH cutters
RH cutters
Always grinding from the outside in, sparks always away from me.
Spring assisted pulley clamping of the DL's as the motor is pulled down.
Philbert
Chainsaw Enthusiast
5:58 PM
East Dakota
Never tried a MAXX grinder.
The Oregon / Tecomec grinders dominate here, so hard to run across a used one.
And some MAXX grinders got mixed reviews over on A.S.
Would like to try one if I got the opportunity.
Philbert
11:58 PM
Assume it once had a wheel guard on the side?
Philbert
I am usually fairly cautious , but I got annoyed taking it off and putting it on a couple times a day.
I have considered purchasing a second AMA MAXX to reduce wheel swapping, I like this grinder a lot!
Philbert
Chainsaw Enthusiast
5:58 PM
East Dakota
I had one grinding wheel launch on me once. Partially my fault: I did not do a ‘ring test’ first.
It was a small one, but got my attention. Also, got the attention of the wall on the far side of the laundry room.
They also help control/ direct the dust.
Philbert
