- 10:16 PM
- May 24, 2019
- WV/NC
She's not so much of a dog now.
Also planning on rebuilding the motor.
Headstuds
Mainstuds
Stage 1 Cam
Ceramic coated pistons
Chromoly pushrods
160/30 single shot injectors
Mechanical lift pump delete.
Plus what I already have done/was done
5+5 billet wheel, 360 bearing
PHP Orion <- the only tuner available for the ECM
5" Donaldson straight though semi truck muffler
4" back from muffler to a stack
Bellowed up pipes
Gauges
Hpop crossover
Things I have that I need to install.
FAB up a 4" downpipe
Comp Cams Valve Springs
Regulated return
Wastegated 1.0 housing
KC big actuator EDIT: Went to a KC300X Turbo 63/68 .84 housing
Absolutely overbuilt for just 300hp. But when I started pricing everything out I was paying about the same compared to an OEM rebuild kit...... Still more than a 5.9 12v though.....
In this video I my brother flashed it to the 275HP tune which moved the 17klbs pretty well. Downside I don't have a wastegated turbo so it was staying at or just over 30lbs of boost the whole time. I have a suspicion I put it on more of a load it would probably shoot past that and with a gtp38 and stock headbolts I don't think it would be the best idea.
I had him drop it back to 250hp until I can get back home to swap the housing.
Other absolutely massive thing about all this is it moved the RPM limiter up from 2600. I'm not sure what it's set to now but in the video you can watch it climb to 3000 rpm. Even though the paper numbers say the t444e made all its power at like 1800 rpm. It never felt like that in practice. The second it dropped below 2k the truck was done and would plummet . Maybe it was the gearing in this specific set up that caused that.
Headstuds
Mainstuds
Stage 1 Cam
Chromoly pushrods
Bellowed up pipes
Gauges
Hpop crossover
Regulated return
KC big actuator
