Cerberus
Cerberus the aardvark, not the hell-hound!!
- 8:45 PM
- Jan 20, 2020
- Florida (tampa area)
tl;dr-- I was rough, using my impact-gun to remove the lower, clutch-side retention bolt for my full-wrap handlebars...these bars have always exhibited strong outward pressure so the 2 retention screws on clutch-side are "under load" as you're installing/removing them.... They'd been installed many many months back, using red loctite (I falsely thought there were metal inserts/bosses in those 2 holes), but I just had to remove it and using the impact-gun (being impatient) caused it to tear/leak gas from that hole.... Hoping for thoughts on how long-term I can expect a Motoseal-coated screw to reliably seal this, if at all, and anything I should look for insofar as stress marks/fractures from the overload/shock I caused (FWIW I did start the screw by hand at least 1 rotation but until it's several turns out the full-wrap bars put such strong outward pressure on it that it's hard to feel you even started the bolt (and I forgot to place pressure on the full-wrap to alleviate it so the bolt would come out easier, just sloppy work on my part on at least 2 aspects, am blown away it was a plastic screw-boss but I approached it like a neanderthal))
I'd always hated the "outward-pressure" my full-wrap bars exhibit at the saw's clutch-side mounting, anyways all had been fine for like 1/2yr and, just now removing handlebars (tank-sleds being installed on both - ironic!), I (moronically) used my impact-gun to remove the lower clutch-side bolt of the full-wraps and, presumably from the hard-release/cracking of Loctite on that screw (which sits inside the plastic tank's body...), it burst a hole somewhere in that tract/female-bolt-hole!!
I know - it's a cheap saw / this is expected (it's now issue #2, not sure just yet how much a PITB it'll be), just posting to see if others have had this problem/heard of it because I can't tell how much was that "already there, strong-outwards pressure on the clutch-side mount" of the full-wrap, and how much was me being an impatient-moron and using an impact-gun to remove a screw I should've been removing by-hand (to be fair I did actually start them by hand but the outwards-pressure of the bar at that interface leaves that bolt under-tension until it's fully released/un-seated...should've kept the top bolt right above it tighter, and done it by-hand, cannot imagine this would've happened :/
ANYWAY re solutions, I'm not going for a new tank/handle just yet because I cannot help think that the mere re-installation of the handlebar-bolt, slathering it with Motoseal before I install it (into a cleaned channel of course!), I suspect this'll be enough to 100.0% rectify it otherwise will have a "saw cannot be >50% full" issue, as-if you had a leaky fuel-tank-cap annoying but probably not something I'll need to replace for, am examining damages now so figured to post for help if anyone's got advice on what to look for / ways they've proceeded, I know I've heard of fuel tank patching but don't know the 1st thing and this is inside a screw-boss so will inherently be a 'load bearing' area (though I could brace/eliminate that if necessary)
Thanks for any insight/advice!! 1st real faux-660 problem (finally right?? Kinda overdue was almost starting to let it get to my head after how well my big bore came out )
