Piston Skirt
Wheres the chain adjuster for the 390?
Exactly where it was on CS-500. 390/490/500/501 have nicely interchangeable starter assembly, clutch cover (and entire clutch IIRC), chain tensioner and air filter
@AlfA01, any chance you can get me a 1/4" drive sprocket for my CS2511-T?
https://www.echopartsonline.com/echo-part-A556001710/@AlfA01, any chance you can get me a 1/4" drive sprocket for my CS2511-T?
Already ordered a 14" Rollomatic dime tip bar and three Stihl 1/4 chains....just gotta mod the bar when it gets here and get a sprocket.....https://www.echopartsonline.com/echo-part-A556001710/
Just don't use Oregon .050 1/4 chain, 3/8 .043 handles about the same and cuts faster at least in "big" wood. Stihl chain would be best... as always
I'd like to find a spare muffler so I can gut one out.I’ve seem a couple of you tubers like bucking and August, have had it modded by walkers saw shop iirc. Which involved by passing the cat and using a stihl bar with the 1/4 chain and 1.1 mm (o.43] bar.
That YouTube vid posted above did not sound like it had a muff mod done on it.
I'm waiting to hear this answer myselfAnyone know the difference between this and the 2511t?
Up in the tree limbing and topping, the 1/4-.043 is the cats ass on a saw. After watching August running his modded 2511, I'm convinced the 1/4 is the way to go on this particular saw.I prefer the kerf on a 325 for forestry use. For firewood, the 3/8 would prolly work just fine. But you will also sharpen even NK 325 much less often than 3/8.
The bar shouldn't be a surprise as they are Japanese. Tsumura is ubiquitous on Echos and Shindaiwas as well.
I bought one last Friday and now I'm waiting on my bar and check sins from the local dealer, and hoping that @AlfA01 can get me a sprocket.
Dan, is the oil pump drive worm different on the 1/4 than it is on the 3/8? It's not a "gear" on this saw, but rather a little "tang" that seats against a tooth on the sprocket.
Page 7 for the muffler:I'd like to find a spare muffler so I can gut one out.
X2. Nate's pretty much my go to for anything echo. When I broke the brake flag on my 2511 he pulled the one off his floor model so he could get it to me quicker. Had it here the next day!Scott, maybe try Nate at https://www.performanceoutdoorequipment.com/ If anyone in the States has them in stock he does, he's the first one I heard talk about that mod last fall.
So that’s where it went... I was ready to pull the trigger last fall but the only one he had was without a brake...
I'm doing pretty good buddy, the wicked winds have been keeping me busy though!!
How are you?
Please let me know ASAP about that sprocket, I wanna mod this CS2511-T as soon as I can.
