This one wasn't discussed lol. Forgot I even had it till the other day. But some of the parts from what we discussed were used here.I think I remember you telling me your idea for this saw. Stoked to see it worked out!
Wow should be a great runner even with stock ports. But the trans and ex can come up a pile. Look forward to how this turns out.
Very cool amigo, I like seeing new stuff done. If someone was handy they could also add material to the piston and have it machined to spec
You pass that this way?
Waiting on a muffler to arrive.
Hopefully Sunday I can get it all cleaned up and put together..
Unsalted.Salted or unsalted ?
LOL. I ask for unsalted fries, so I know they're fresh.Unsalted.
That way it be made fresh...
I'll add salt.
Should be faster than when I started...Looks fast anyway
we can calculate it if we know how much shorter the pin to crown height is. I think you will be close with the numbers you have.Should be faster than when I started...
Anxious to get this one going. Figured with all the extra comp the higher exhaust should be manageable. Wish I would have took the time to clean the stock piston and get some baseline numbers.
Have to wait till my 530 shows up
I'll get some measurements tomorrow. Was thinking about plugging the numbers into the program. Cause this clamshell thing adds some difficulty to laying out ports with a ring and degree wheel.we can calculate it if we know how much shorter the pin to crown height is. I think you will be close with the numbers you have.
