Echo cs 510 build
Red97
1:24 AM
MI
Neat little 50cc saw. Mag cased clam shell.
Pretty gunky, should clean up well.
Red97
1:24 AM
MI
Cleaned up well considering..
Ample port size for any echo I've seen. Only thing I can't figure out is why they dropped to a at size carb from hda....
Red97
1:24 AM
MI
Had a 254xp meteor, and a top secret wrist pin bearing from another project. What ya know it fits...
Had to take approx .030 out of the band.
Numbers
In 71
Ex 113
Tr135
Red97
1:24 AM
MI
I think I remember you telling me your idea for this saw. Stoked to see it worked out!
This one wasn't discussed lol. Forgot I even had it till the other day. But some of the parts from what we discussed were used here.
David Young
Safety First !!!!!!
1:24 AM
vt
Wow should be a great runner even with stock ports. But the trans and ex can come up a pile. Look forward to how this turns out.
TreeLife
I'm Dominick
1:24 AM
Berkshire County, Massachusetts
Very cool amigo, I like seeing new stuff done. If someone was handy they could also add material to the piston and have it machined to spec :)
Red97
1:24 AM
MI
Probably should have checked the timing with the stock piston first. But I got carried away making the hoosky piston fit.
Probably gonna raise em up 5* or so
The taller piston is the easier way to go. Just had to open up the pin boss a bit for the echo rod to fit.
Probably could have shaved .015-20 off the piston, and cut the band less to get the numbers I was looking for with less grinding.
Hopefully I can find another 1 or 2 of these to play with...
12:24 AM
You pass that this way?
Waiting on a muffler to arrive.
Hopefully Sunday I can get it all cleaned up and put together..
Salted or unsalted ?
Red97
1:24 AM
MI
Cut a step in the exhaust floor.
Raised the transfers/exhaust a pile.
Dropped the center of the intake just a bit.
Numbers are 105 ex 126 tr and 73 intake
David Young
Safety First !!!!!!
1:24 AM
vt
Looks fast anyway
Red97
1:24 AM
MI
Looks fast anyway
Should be faster than when I started...
Anxious to get this one going. Figured with all the extra comp the higher exhaust should be manageable. Wish I would have took the time to clean the stock piston and get some baseline numbers.
Have to wait till my 530 shows up :)
David Young
Safety First !!!!!!
1:24 AM
vt
we can calculate it if we know how much shorter the pin to crown height is. I think you will be close with the numbers you have.
Red97
1:24 AM
MI
I'll get some measurements tomorrow. Was thinking about plugging the numbers into the program. Cause this clamshell thing adds some difficulty to laying out ports with a ring and degree wheel.
1:24 AM
The cylinder layout looks similar to a 395
