- 5:38 AM
- Dec 30, 2015
- Centre County
Any way you can try a different coil? Is this the 490 coil or 4910?
Maybe try higher octane fuel?
That’s interesting. No, I haven’t pulled compression. I doubt it’s super high. I only took 0.025” out of the band (squish is 0.022”) and there’s no air up here. But I’ll check it. I’ll also order a new tach. Mine fell out of a tree and isn’t trustworthy.I’m asking about the Compression because my 361’s actually require a timing retard to not pop.
Other people, that dont have the same compression as me, actually advance the timing.
I believe it will.An actual 4910 coil may work. Not sure if it will work with the 490 flywheel or not.
I saw those. I may be doing the same.I'll be testing this one in the next couple weeks.
Cartridge style filter and 3d printed cover.
Something new from Nick?I'll be testing this one in the next couple weeks.
No, it was on eBay. Guy reached out on youtube.Something new from Nick?
Here’s a bit of fun. Turns out the trigger travel was just maxing out, the linkage wasn’t bending enough to matter. So I extended the trigger side with an old 9mm cartridge. Butterfly opens completely now.
Great info there. 35 degrees seems a bit aggressive. Are you able to find the same technical data for 501p? I tried a google search, but only got sales pages and operators manuals.Here's the CS500p technical data....same coil/flywheel part numbers as the cs490
Looks like 35* BTDC @10K RPM
Also has resistance specs for primary and secondary windings...Probably worth checking as well.
Thanks! Interesting that they dialed back the timing, especially for the heated version. I wish the heated red ones were available in the US.
Still sitting at 78-105-124/128. I was already inclined to even out the transfers so I’ll do that while I have it apart. Undecided on the lowers. I’m tempted to blend the primary.Where did the ports end up?
