Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
mettee
11:57 PM
Arizona
Copy that.
Good read in this thread for dolmar/makita guys.
I'm super curious about your staggering of the transfer ports. Can you share your theory on that?
mettee
11:57 PM
Arizona
Gonna try this
2:57 AM
Oh and dolmar and husky are silly for not putting a nut on the clutch to remove it like a stihl. Rediculous that you need a special clutch tool... that I had to buy.
T.Roller
2:57 AM
Southeast, TN
Copy that.
I talked to a few guys that have alot more knowledge and decided to run them staggared 3 degrees. Suppose to give a wider power band.
mettee
11:57 PM
Arizona
They make these uni in dual layer, I'm thinking I'll make a set up for that with an aluminum velocity stack that mates to the HD filter lower boot and elbow. I have a K&n that I got to mess with but I think these foam ones filter more reliably without compromising airflow?
mettee
11:57 PM
Arizona
So in theory, you have a target number for the timing, and what you are doing is starting one degree before on the secondary transfers and going to one degree past on the primary transfers?
T.Roller
2:57 AM
Southeast, TN
Set my primaries to open and then 3 degrees past my primaries I open the secondaries
mettee
11:57 PM
Arizona
Do you cut wood with that saw, or just keep it on the shelf? Lol
Nice saw.
Freshly ground up rebuild. Got all my stuff from Nate who I highly suggest to anyone. It was super beat up when I got it from home depot. I think I paid 280 for it.
It's gonna eat wood for sure.
T.Roller
2:57 AM
Southeast, TN
Trimmed a little bit
I think the K&n will filter well as long as you were to also use the filter sock screen they have. It would be hard to beat that performance.
Where did you come up with this setup. I'm very disappointed in the stock filter setup and would like this setup.
mettee
11:57 PM
Arizona
Only one k&n would fit, k&n ru-2550
Then the velocity stack can be turned on a manual machine or cnc. I have one drawn up in solid works.
Tons of room for the velocity section of the adaptor.
2:57 AM
Just funnin ya. Awesome job on the rebuild. Looks brand new. [emoji106]
Nice filter on it too!
mettee
11:57 PM
Arizona
I was apprehensive about using the K&n just because they don't always filter the best, but in my experience with these in automotive apps they do well when they have the mesh sock for dual layer filtering. It's not for everyone unless it actually ends up being heavy duty enough. I use a touch of three bond on each connection so there is no chance to draw in fines.
