GBertolet
I just worked on a Tecumseh LEV80, 3.5 hp engine. The rehab turned out great. Starts first pull, and I mowed the yard with it several times. I went to start it for another use, and couldn't pull the starter cord. Hydraulic lock?? The muffler was wet with fuel, and the fuel tank was empty. I took the sparkplug out, and gas ran out of the cylinder. Lots of it. I removed the filler cap to check the oil, and gas gushed out the oil fill. Must have entered through the breather. I drained the oil, and got well over a quart out. I took the carb apart, and could find nothing wrong. No dirt in the bowl. Float, needle and seat looked ok. I ultrasonicly cleaned it previously, as a part of the rebuild. I then put the carb back together, refilled the oil, added a little gas to the tank, and it started first pull, and ran fine. Any ideas on what the heck happened?
