Well that’s some valuable information I needed...
AUD? If so the OP might still be interested. Up to him ay.Electrosil quoted $500- plus for a 056 Magnum cylinder, that was over ten years ago.
if your project is a money is no object, unobtainium unicorn situation, there is a place that will likely do it but the bill will be at least a grand, if it is worth it let me knowThank you so much Dave. That is exactly the information I have been looking for and is very through and clear. I really appreciate it. Unfortunately, it looks like I am out of luck for getting my 1.5" / 38mm blind bore plated. Too bad, but at least I can end my quest t have this done. maybe I can get it to kinda run as-is... Who knows, maybe things will get better or maybe someone else will eventually enter the blind bore plating business. One can always hope right?
-Matthew
We are working with some other good folks both here and elsewhere to make blind boring possible again. That@Definitive Dave who would be able to blind bore then?
What's the cylinder Matthew. Maybe a worldwide stumble upon search might pay dividends? It's only one more search term of a daily listings check in my case for instance.Thanks so much for all the replies. I have reached out to Electrosil in Australia and I will see what they have to say and let the group know.
-Matthew
US Chrome will plate them for us, but can't hone and finish the bore below 47mm (1.8")
this is correct, I understand why after a lengthy conversation with them, but it is basically too expensive to buy the tooling (and skilled labor) to finish Diamond hone the bore after plating - nobody wants to pay $2500 to replate a standard 034 cylinder right?So US Chrome could replate a 034 Super cylinder (48mm)....But on a standard 034 cylinder (46mm)?
My neighbor has diamond tooling. So far nothing has been impossible there. He can do bores. Not sure if he is interested but I can ask.this is correct, I understand why after a lengthy conversation with them, but it is basically too expensive to buy the tooling (and skilled labor) to finish Diamond hone the bore after plating - nobody wants to pay $2500 to replate a standard 034 cylinder right?
Link?My local pawn shop has a "complete" chrome plating setup for sale
