Carburetors - Custom or High Performance Installations
  • Thread starter Thread starter Backyard Lumberjack
  • Start date Start date
jmester
9:14 PM
VIRGINIA
Got some outerwears for those 394 hd filters I run. part number 100-4567. Had to do a custom order but thought it might help some others if they have an interest in outerwears prefilter.IMG_0604.JPG IMG_0607.JPG
jmester
9:14 PM
VIRGINIA
You can fill out the custom build form in the link or email the lady I talked to at outerwears. Just know that's there is a $15 custom build fee. Plus the filter. Link for custom build. http://www.outerwearsracing.com/custom_oval.asp
Email for the lady I dealt with is nicki@outerwears.com
Part # 100-4567
Outerwears custom built PRE-FILTER to fit 4 1/8" DIAMETER (FOR OCTAGON SHAPED FILTER), 1 7/8" TALL, NO TOP WITH EDGE TO EDGE FIT, WATER REPELLENT BLACK= $6.95
This info should get you what you need.
Please let me know if you need anything else. Or if I can help in any way.
jmester
9:14 PM
VIRGINIA
Did you ever get your outerwares?
srcarr52
9:14 PM
Iowa City
How are they working? Staying on ok?
jmester
9:14 PM
VIRGINIA
Yes they stay on well. I really like them on this filter. Filter last a lot longer especially for me as I run an open filter.
jmester
9:14 PM
VIRGINIA
Finally installed the complete euro conversion parts on the 661 today. Had the parts for a couple of months. Cut some cookies with it and seems to do well. I will use it next week to cut timber will let you all no how it does.IMG_0679.JPG
jmester
9:14 PM
VIRGINIA
I am running the stock air filter setup for now. I may switch to the 394 filter setup again just wanted to see how it does this way first then change things around then.
jmester
9:14 PM
VIRGINIA
Just some mock up pics.
Notice in the second pic the brass bushing / spacer. They are 4.5 mm thick. I used the bushing out of a busted 660 top cover. You need them so you don't break the horn or filter base when you tighten the nuts down.
I have found that's a thinner bushing works better. Pulls the filter base in tighter and helps hold the switch shaft better. I made them .139 thick. I started with sleeves from a Stihl hedge trimmer part number 4237 641 4903. They need to be ground, filed or milled to the correct thickness.
