jmester
You can see in the first pic where I crushed the horn down with out any inserts in it. Then in turn it mushroomed out the insert for there was no support. Other wise I like it better then having longer studs made.
Would you be willing to make a couple of those for me? Looks good and should work well with the 394/395 filter horn.
so cool!Got the set up done on my 661 today. Have the WJ-76 installed with a .68 fixed jet. Still waiting on the euro coil and correct carb grommet. Think it turned out well. Will be interested to see how it runs.View attachment 51511
Finally got the euro coil and correct carb grommet. Should have time to tune it tomorrow. I am looking for to cutting some timber Monday with it.View attachment 63719View attachment 63720
He sent me that same coil to play with. I never got a reading above 13.3k. The manual in my thread about the different coils shows a page that says set as close to 13.5k and then an 1/8 turn leaner past the limiter.I saw your post about that. That's should be fine for me any way I usually set them on the high side at 13,200. I like the fuel. I think I saw that moparmyway's euro coil went to like 13,800. Maybe it was the 4701 coil.
