DigB
- 2:16 PM
- Jan 7, 2017
- stoopidvania
I am looking for suggestions on how to repair this crankcase, if it is even worthwhile, and some other help with this 266SG that I plan to build into a 272. It is cracked through, but not into the threads for the oil filler.
And here is the other side:
My first thought is to find a magnesium welder in my area, Cumberland County Pennsylvania. Any recommendations or shout-ins? I have asked around but no luck.
I wonder if any of those aluminum solder products could work here?
Then there's glue. Maybe I could glue a reinforcing sheet on each side. And add some rivets for suspenders.
Or I could buy a new aftermarket crankcase. Do they accommodate the heated handle wiring?
But there are more challenges. I have have a collection of 61 parts that will fill in most of what is missing, but not the two-piece ignition. I would like to hear about peoples' experience with the very cheap ones on ebay, or others. I have the module with the spark lead, and it meters OK.
For heat to the upper handle, somewhere I have some resistance wire that I used to make heated gloves, but I haven't laid my hands on it yet. I believe it was beadalon. It looks like I will need almost 30 inches measuring 3-4 ohms. Recommendations?
One more thing. Even though the black tag starts with a 7, it has a metal tank and there is a smidge of corrosion where is touches the ground. What's the best treatment there?
I should note that in this part of Pennsylvania it does not get cold any more and I am not required to cut any day, let alone one that is cold enough to warrant heat. So this is truly a recreational project. And as always, I am trying to make sure I can continue to say with pride that it is cheaper than golf.
Thanks friends. Don
Thanks friends. Don
