Broken at cylinder base
Reesedlightning
1:25 AM
Maryland
Hey everyone. Currently working on an 064 that came to me as a basket case with low compression among other things. Found a crack in the case where the cylinder mounts up. Gave the part a good hard wiggle by hand and it broke right off. Never seen anything quite like this. Is this fixable via JB weld or do I need to find a shop to rig weld this thing?
Reesedlightning
1:25 AM
Maryland
That’s what it looks like to me too. Someone was in this saw before me. I found all kinds of issues. The clutch side bearing is trashed so I was going to split the cases anyways. Could I possibly use a donor case half or should I stick to a whole new case?
1:25 AM
Not certain about mismatched stihl cases. I’ve seen .020” difference in deck height
Sauen
7:25 AM
Netherlands
I’ve fixed an 066 with JB weld where the conrod had punched through that spot. Has held up fine and was easy to do.
Funky sawman
Pony Power
10:25 PM
North idaho
Kevin is spit on with that. Of all the basket cases I've tried to cobble together, only like 5 percent of mismatched cases actually line up and are square with one another
Reesedlightning
1:25 AM
Maryland
Solid info. Thanks. I was starting to wonder what the likelihood of cases matching was. I have a 266 with a 272 top end on it that I won in a raffle and once I got into it, I realized the cases were mismatched and man what a headache that was just trying to get the cylinder to sit flush
