HuskyHead
- 1:17 AM
- Jun 8, 2021
- Georgia
Alright so I’ll ask a question that has been asked before I am sure. Also if it’s not in the right location please move. So I’ve been looking and reading about base gasket deletes. So far I understand that I’ll need to check squish after removing the factory gasket using thin solder in the .025-.030” range. Look for nothing tighter than .020”. I am sure the best solution is to machine the jug to fit to correct or desired height. So my question is if I remove the factory gasket what’s the preferred gasket solution? Obviously there are varying thoughts on the best sealant Loctite 515/18, Threebond1184, Yama/Hondabond,Motoseal, Dirko, but what about making your own thin gasket? I’ve seen things ranging from paper to aluminum cans (see picture below, not mine nabbed from Google). I assume if you make your own gasket you’ll still need to place a thin layer of sealer on one or both sides of the homemade gasket? Which is best or preferred? Also I might have access to a 3D printer wonder if I could make one out heat resistant polymer(plastic)? Also I’ll be doing this to a MS440(B4 a ride to @huskihl) and maybe my 550Mk2.
